Fusibili S1
2 partecipanti
1Fusibili S1 Empty Fusibili S1 Lun 09 Nov 2015, 1:21 pm
RegulusS1
RegulusS1
Ragazzi qualcuno ricorda a memoria quanti sono i fusibili all'interno del cofano? Intendo quelli fuori dalla scatola.
Io ne ho trovato 1 da 20, 1 grosso da 30 e 2 da 50. Ce ne sono altri?
2Fusibili S1 Empty Re: Fusibili S1 Lun 09 Nov 2015, 6:13 pm
Ti riferisci ai Relè?
Fusibili S1 Immagi15
Fusibili S1 S1mainfuses
Slot  Rating  Circuit
1  3A  Rear fog lamp
2  2A  Alarm ignition
3  20A  Interior fan
4  15A  Wiper motor
5  3A  Reverse lamp
6  7.5A  Direction indicators
7  10A  Ignition services
8  7.5A  Stop lamps & Battery services
(Stack speedo, tacho and LCD)
9  10A  Hazard lamps
10  7.5A  Horn
11  10A  Alarm & Interior lamp
12  25A  Cooling fan
13  BLANK  BLANK
14  20A  Audio
15  20A  Cigar lighter
16  5A  Sidelamp LH
17  5A  Sidelamp RH and Stack illumination
18  BLANK  BLANK
19  BLANK  BLANK
20  20A  Fast fan speed relay
21  BLANK  BLANK
22  BLANK  BLANK
Early Elises (pre Oct 97) have several fuse boxes. The main one is located on the left hand side of the front services compartment. A smaller fuse box is located underneath the windscreen motor cover. The fuel pump fuse is located near the ECU at the rear of the car (LH in the boot).
Slot  Rating  Circuit
1  3A  Rear fog lamp
2  2A  Alarm
3  15A  Interior fan
4  15A  Wiper motor
5  3A  Reverse lamp
7  5A  Ignition services
9  10A  Hazard lamps
10  7.5A  Horn
12  25A  Cooling fan
Fusebox under wiper motor
Slot Rating Circuit
13 20A Radio
14 20A Cigar lighter
15 5A Sidelamp LH
16 5A Sidelamp RH
Fuel pump fuse located near ECU LH
Slot Rating Circuit
17 10A Fuel pump
Elise S1 Relays
A  Horn
B  Cooling fan
C  Dip beam
D  Main beam
3Fusibili S1 Empty Re: Fusibili S1 Lun 09 Nov 2015, 8:03 pm
RegulusS1
RegulusS1
Yes! Comunque ho già risolto, ne avevo fatti saltare ben 3.
Non chiedetemi cos'ho combinato Very Happy . Sto testando un nuovo "aggeggio", lo recensisco appena riesco a farlo funzionare Wink .
4Fusibili S1 Empty Re: Fusibili S1 Lun 09 Nov 2015, 9:55 pm
Come cavolo hai fatto a far saltare 3 Relè su 4. affraid affraid
Cosa stai combinando, occhio che non si fulmini tutta l'auto. Very Happy
