Un progetto da 500cv... Non fatevi troppe pugnette!
-Full Race twin scroll manifold
-Borg Warner AirWerks custom S300SX FMW 1.10 A\R Cupped tip V-Band
-2 Tial MV-R 44mm
-Tial Q-Bov
-Garrett intercooler 1000hp
-Full Race 3" intercooler piping
-Full Race 3" downpipe + mide pipe
-Full Race dumptube
-Full Race hardware,fittings,lines,oil\drain kit
-Mishimoto Radiator+Slim fan+switch
-Okada Plasmajet Ignition
-Tein Mono Flex Damper
-Aereomotive 340lt\h fuel pump
-AEM fuel press.reg.+fuel rail
-IN LINE PRO sistema ritorno carburante
-ID 1000 c.c. iniettori+s2000 p&p wires
-Hondata 4bar map
-Hondata Intake gasket
-Full Blown DSS 850hp trasmission system (differenziale,semiassi,piatteli,bulloneria ARP ecc...)
-Avid Racing Engine mounts
-Avid Racing trasmission mounts
-Ferrea competition plus 6000 valvole int.+ext.
-Ferrea twin spings\titanium retainers\seats
-Ferrea guide valvole
-Ferrea seals lock
-Pauter bielle X Beam 350HP cad.+ARP bolts
-ARP motor+engine bolts\studs
-CP Piston 88mm 9,0:1 CR
-Cometic gasket OEM tick 89mm bore
-Greddy\Trust Radiatore olio 13 row+kit rilocazione filtro
-ATS Magnum trimetallic plate complete kit
-ATS pull to push clutch system
-TODA heavy duty tensioner
-TODA heavy duty chain
-TODA heavy duty oil pump
-Darton M.I.D. sleeves block (testate fino a 5bar di press.)
-IN Line Pro albero motore bilanciato e lucidato
-Hondata Flash Pro
-Hondata Boost Controll solenoid a 4 vie
-PB Racing 13" Big Brake kit pinze 6 pompanti,dischi scomponibili,campana in ergal,pinze monoblocco,raccordi teflon
-Project Mu pastiglie
-Ultimate Racing sistema di scarico 3" no cat. straight pipe V-Band flange
-Kit rimozione EGR+Air Pump
-Kit aria condizionata
-T1r pulegge
-2 Tial MV-R 44mm
-Tial Q-Bov
-Full Race dumptube
-Hondata 4bar map
-Ferrea seals lock
-Hondata Flash Pro
-T1r pulegge
