BROOKE CARS
About Us
At Brooke Cars our aim is simple, to build beautiful and finely engineered sports cars with the potential to outperform the very latest supercars and reward the driver with a truly thrilling experience. Do not be fooled by the elegant and classic lines, the Brooke Double R is a modern thoroughbred using state of the art components from such well known brands as Cosworth, AP Racing, and Stack to keep us at the cutting edge.
We believe that the ultimate sports car should have a longitudinally mid-mounted engine, the fact that every Formula one car since the sixties has used this design surely confirms that this is the ultimate configuration. The Brooke Double R is also incredibly light, weighing in at around 510Kg depending on spec. These slender figures combined with engines ranging in power from 200-400bhp give the Brooke Double R acceleration to shock and awe.
A space frame chassis that is light yet exceptionally strong.
The Brooke Double R chassis has been CAD designed using the latest software. Unlike many of our competitors our chassis is manufactured from seamless round tube because it is much stiffer than the square alternatives. Every chassis tube is cut on a CNC tube laser, so every intersection between mating chassis tubes is perfect. All of the chassis jigs are CAD designed, this use of technology allows us to produce a highly accurate and remarkably stiff chassis which is of course the basis of a fine handling car.
http://www.brookecars.co.uk/index.php
Mi ricorda molto le bellissime lotus 33, 38 e 49!
