Kit Turbo da 307 cv per SOLI 4.655 EURO.
Direi sbalorditivo.
Product Details
THIS PRODUCT WILL BE RELEASED FALL 2011
The Hard Parts Turbo Kit is a complete bolt-on kit and includes everything needed with the exception to the engine management system and any engine wiring harness adapters. NOTE: In late Fall 2011, we will be releasing our Lotus Plug N Play Programmable EMS. This Hard Parts kit is ideal for someone using a stand-alone EMS, piggy back ECU, or reflash ECU that their tuner is comfortable using.
This kit is designed to be a complete bolt-on system that requires no special tools or permanent modification to the car allowing the vehicle to be returned to stock if necessary. Furthermore, all factory equipment is retained but the relocation of certain items is required for proper installation.
The following is a list of the contents of the Radium Engineering Hard Parts Turbocharger Kit:
Garrett Turbochargers
We have selected watercooled Garrett Turbochargers for our Lotus kits. The GT2860 is our the entry level turbocharger which is best fit for a daily driven 2ZZ-GE engine. Available in journal bearing for cost efficiency as well as dual ball bearing ("disco potato") for quicker spool. Both have the same GT aerodynamics that offers very quick spooling along with ample air flow for over 350hp.
