Vendo in blocco numerosi ricambi nuovi Lotus
1Vendo in blocco numerosi ricambi nuovi Lotus Empty Vendo in blocco numerosi ricambi nuovi Lotus il Gio 13 Ott 2011, 4:17 pm
Luciano
Vendo solo in blocco numerosi ricambi Lotus per Esprit, Elan, Elise.
Telefonare per eventuali informazioni +39 393 4681955 sig. Giordano
Non rispondo a email.
A100E6273H AIR FILTER
A111E60415 CINGHIA ALTERNATOR BELT
A111E0050F ECM CENTRALINA
A082J6109F FRONT PAD SET
A082J4390F BRAKE HOSE ELISE BREMBO
B920E00172 TAPPET STEEL
A910E6929F FUEL FILTER
B082M6442F RESISTOR SECONDARY INJECTOR
A111F6020S ELISE SPEEDO DRIVE
A91006927F SENSOR M.A.T.
A082F6392F SEAL GEARBO
A907E6332F DRIVE BELT
A111E6050S GASKET SET LOWER
B100M0106F HEADLAMP MOUNTING OUTER
B100M0107F HEADLAMP MOUNTING OUTER
A100J6057S BRAKE PAD SET REAR
A100J6050S FRONT PAD SET
A100U0095F BOOT LOK CYL 2 KEY TEXTPO
A11YE6037S ELISE DISTRIBUTOR CAP
A111E0020S AIR FILTER ASSEMBLY NOTORSPORT
A111004785 ALLOY WINDOW WINDERS ELISE
A111E60415 ALTERNATOR BELT
A111E6060S FUEL INJECTOR
A111E6054S OIL SEAL CRANKSHAFT FRONT
A100M6090F HEADLIGHT
B11140062P HEADLIGHT
E1D0C6001F
C100M0013F FRONT SIDE IND LAMP
A111C0075F SOSPENSION BUS
A111E6057S OIL SEAL CRANKSHAFT REAR
A910E6929F FILTRO BENZINA
AO82N4057F SPEEDO METER
B111COO64F SHIM FRONT CAMBER
A111K6001F PRESSURE CAP
A111E6061S SENSOR INLET TEMPERATURE
A111M6009F BULB HOLDER SIDE REPEATER
A111M6047S WASHER PUMP
A111L6015F O RING VITON 90 MM
A11156014F GASKET EXHAUST CATALYST
C100J6019F SERVO MASTER CYL ASSY
B100E6085S OIL FILTER
A100J6008F REAR CALIPER PADS
A100J6064S REAR CALIPER RH
E100BO574F POD FRAME ASSY RH
B910E1390F
A111E6056S SEAL OIL FILTER
A111C6016F CIRCLIP WHEEL B
A910E6928F SENSOR COOLANT TEMP
A100M0248F HEADLAMP RING RHINNER
A111F6018H R B A111F6018F 25.02.98
A912E6694F
A111VOO87K FINISHER A POST LOVER LH
A111VOO86K FINISHER A POST LOVER RM
A111C6002F WHEEL BEARING ELISE
A111E0020 1 AIRBOX KIT ASSY MOTORSPORT
A100M6033F HEADLAMP OUTER LHD EURO
A111E6039S OIL FILTER CAP
C111BO293F FOAM GASKET CANTRAIL LH
A111L6008F O RING FUEL PUMP
A11156005F GASKET MANIFOLD DOWN PIPE
A111E6035S WASHER DRAIN PLUG SUMP TRANS
AO82F6368F
A111O6024F CAP DOOR HINGE
A100E6131F DRIVE BELT PAS PUMP
A111M6029F R B A 111M6066F DEL 04' 07' 00'
A11106071V TAPE 3M FOAM ADHESIVE
A111E6055S OIL SEAL CAMSHAFT
A111E6065S STUD EXHAUST DOWNPIPE
A111DO133F ROAD SPRING REAR RED RED
A111CO140F FRONT SPING BLUE BLUE
A910E2463K
A082J6157S RR PAC SET E SO
C111BOO51F PLATE DRIVING LAMP MOUNT LH
B111BO243F BACKING PLAZE SPRING KLIP
A111E6040S HT LEAD SET STD
A111E6053S GASKET OIL PUMP
A111W3149F NUT M12
TOOOT1282F CAMSHAFT GEAR LOOKING TOOL
A111E6295S CONTROL UNIT LESS SOLENOID VVC
A111E0020S MOTORSPORT AIR FILTER ASSY
A111J0022F THROTTLE CABLE
B082L4062L MANICOTTI
BOBINE
CENTRALINA L0960004 ENGINE ECM/TYPE 918
A075U0588Z SPACER
A111E6058S GASKET COOLANT SENSOR
C111B0175F SUPPORT SPRING
A111P6003F KNOB HEATER CONTROLS
A82F6494F O RING
C111B0174F SPRING DOOR
A100B6155V
B111U0265F DOOR GLASS LIFT CHANNEL LH
TOOOT1290F
A111W3146F WINGNUT M5 NYLON
B100B1160 H LAMP POD RH
ALTRO MATERIALE SCIOLTO NON CLASSIFICATO
SCARICO COMPLETO LOTUS ELISE 111
CAVI LEVERAGGIO CAMBIO LOTUS ELAN
TELINO COPRIAUTO VERDE CON STEMMA PER LOTUS ESPRIT 111
Ciao Luciano, sara dura vendere in blocco tutta questa roba.
Magari se metti un prezzo qualcuno puo farci un pensiero.
Sono ricambi nuovi?
PS: e cortesemente potresti presentarti?
Quoto tutto. Presentarsi sarebbe gradito.
Luciano
Scusate se non mi ero presentato... Ho scritto altre cose nella presentazione riguardo il materiale nuovo che vorrei vendere in blocco. Il numero di telefono del sig. Giordano (Giordano Motors) è il seguente: 393 4681955.
Il prezzo di tutto il materiale è di 4000 euro. Ci sono anche tre kit Motorsport, uno scarico completo, un telo copriauto verde con stemma centrale.....
Io capisco l'esigenza di vendere il materiale in blocco, ma noi non siamo dei concessionari Lotus, quindi sara dura che qui dentro qualcuno compra una marea di roba che non gli serve solo per averla a casa, anche perché non sono neanche tutti ricambi della stessa macchina, cosa me ne faccio per esempio del copri auto di una Esprit?
Il consiglio che posso darvi è quello di contattare una concessionaria Lotus e proporre a loro l'acquisto in blocco, vedi Lotus Cerini, Lotus Roma, Astrocar ecc...
Poi per carità voi potete provarci a venderla in blocco ad un privato ma io dubito che ci riusciate.
Detto questo buona vendita e grazie per esserti presentato.
Credo anche io: c'è roba che interesserebbe solo un conce, ma di cui un privato non saprebbe cosa farsi.
ferbigo ha scritto:Credo anche io: c'è roba che interesserebbe solo un conce, ma di cui un privato non saprebbe cosa farsi.
Si appunto, ma metti anche che ci sono cose interessanti anche se devi star li a guardare codice per codice per capire se sono ricambi per la tua Lotus.
Penso anche che si possa guadagnare molto di più di 4.000 euro vendendoli separatamente.
Luciano
Vi ringrazio del consiglio. Eventualmente se sentite di qualcuno che fa i mercatini tipo Novegro e gli può interessare tutto il blocco segnalategli l'annuncio.
Grazie a tutti.
Luciano
Se a qualcuno può interessare posso inviare la lista in email.
10Vendo in blocco numerosi ricambi nuovi Lotus Empty Re: Vendo in blocco numerosi ricambi nuovi Lotus il Gio 20 Ott 2011, 10:27 am
Luciano
Chiudo la discussione perché ho venduto tutto il materiale in blocco.
