P.G.O. HEMERA
+4
piuma
Pako77
8 partecipanti
1P.G.O. HEMERA Empty P.G.O. HEMERA Mar 02 Mag 2017, 9:13 am
Pako77
Pako77
ciao a tutti,
ieri navigando su youtube mi sono imbattuto in questa strana vettura PGO HEMERA e mi ha molto incuriosito ha un motore 1.6 BMW turbo ed è posizionato posteriore centrale, , pesa 990kg a vuoto.
https://www.youtube.com/watch?v=OmZvL5a9wNQ
ENGINE
Engine position: transverse mid engine
Number of cylinders: 4 aligned
Cubic capacity (bore x stroke): 1598 cm3 (77 x 85,8 mm)
Number of valves: 16, twin overhead camshaft, BMW Valvetronic
Power Supply: multi-port direct injection, turbocharged
Maximum power: 135 Kw (184 ch DIN) from 5400 to 6450 rpm
Maximum torque: 240 Nm (24,4 mkg) from1600 to 5000 rpm, 260 Nm in over-boost during 10 sec between 1730 and 4500 rpm
Compression level: 10.5 :1
Depollution system: 3-way catalytic converter
TRANSMISSION
Gear box: manual, 6 gears + reverse
FRAME / STEERING
Font axles: McPherson system, with lower triangulated arm, transversal sway bar
Rear axles: McPherson system, lower multi-arms
Breaks: 4 ventilated discs
Wheels: 7×17 alloy wheels
Tires size: 205/40 ZR 17
Steering: pinion steering
Turning circles between curbs: 9,40M
WEIGHT, VOLUMES AND DIMENSIONS
Kerb weight: 1012 Kg
Fuel tank capacity: 42 liters – Trunk capacity: 240 dm3
Length: 3735 mm – Width: 1735 mm – Height: 1307 mm
Wheelbase: 2261 mm – Front and Rear Track: 1440 /1430 mm
PERFORMANCE AND CONSUMPTION
Maximum Speed on Track: 225 Km/h max.
Fuel consumption, in liters (Unleaded 95RON)
Urban/extra urban /combined drive cycle: 10,4/5,9/7,6
CO2 Emission: 175g/km
cosa ne pensate???
2P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 02 Mag 2017, 9:49 am
piuma
piuma
Inguardabile
3P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 02 Mag 2017, 11:17 am
Eh... Per brutta è brutta.
Ma sarà un prototipo... Non credo una produzione di serie.
4P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 02 Mag 2017, 1:24 pm
Interessante il motore meglio sorvolare sul resto
5P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 02 Mag 2017, 1:54 pm
Pako77
Pako77
l'auto può piacere o meno esteticamente, però una vettura a motore centrale con 185cv made bmw e 990kg di peso a secco non è poi così malvagia
ne fanno anche una versione speedster http://www.pgo.fr/
6P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 02 Mag 2017, 2:11 pm
Question Question Question
7P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 02 Mag 2017, 2:22 pm
De gustibus è una linea ricercata e quasi quasi preferisco la speedster.
Bisognerebbe provarla perché non è solo il rapporto peso potenza ma è anche come sono distribuite le masse, erogazione motore, upgrades, piacevolezza di guida.
Ci sono altre auto che sono inguardabili, questa ha un parabrezza stile Daihatsu Materia, certo ce ne sono molte più belle ma se va forte chissenefrega
8P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 02 Mag 2017, 2:46 pm
Pako77
Pako77
sarebbe interessante sapere se qualcuno nel forum ha avuto modo di provarla
9P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 02 Mag 2017, 6:37 pm
fabioB
fabioB
Mah, come linea mi sembra goffa.
Se e per posizione centrale preferisco la Ginetta g40 gt5 (1.8-160cv-805kg) o sicuramente la c4 come linea.
Oppure questa
http://www.roding-automobile.de/en/roding-automobile/enterprise/about-us.html
10P.G.O. HEMERA Empty Re: P.G.O. HEMERA Mar 27 Giu 2017, 5:03 pm
diaccio
Allora mesi addietro x curiosità mi studiai il modello ... remake in chiave moderna della PGO Speedster e Speedster II.
Piccola casa costruttrice francese che stavolta ha preso il motore della mia R56 lci Cooper S 1.6 di derivazione PSA con sistema Valvetronic e 184 cv.
Il motore è valido e senza i problemi del precedente PSA 174 cv che era però più cattivo nella erogazione.
Lo schema meccanico in teoria dovrebbe darle più prestazioni di una mini oltre ad un peso inferiore.
Ne venderanno 5 ogni anno ma secondo me manterranno valore essendo auto di nicchia.
Potendo scegliere meglio la roadster.
