Alberi a Camme TF 135 X Rover
+2
6 partecipanti
1Alberi a Camme TF 135 X Rover Empty Alberi a Camme TF 135 X Rover Mar 03 Dic 2013, 1:07 am
Amici miei, ho un occasione unica e ghiotta.
Alberi a Camme TF 135 X Rover 631
Una coppia di alberi a camme per Elise S2 rover 122cv.
Sono le mitiche TF 135, quelli montati sulla Elise S2 135R che aveva 135cv.
Infatti questi alberi a camme, è la migliore modifica che si può montare sulle nostre Lotus elise S2 122cv Rover senza modificare la centralina, l'unica e ultima modifica che vi fa recuperare 15/20cv veri e garantiti, non ci sono ne se ne ma.
Praticamente sono le PTP R140 che trovate a 465 sterline  :
Product Information
Originally used in the S2 Lotus Elise 135 and MGTF135
•Improves all round grunt and acceleration.
•Direct replacement for original camshafts & Suitable for all 1.6 and 1.8 K Series standard engines.
These R140 camshafts were originally used in the S2 Lotus Elise 135 and MGTF135. These camshafts have a higher lift with longer valve opening duration over the standard cams. When fitted in the 1.8 litre K series engine you will see a significant increase in the overall power and torque for better all round grunt and acceleration. No change is made to the driveability or tick over (idle speed) once fitted. These cams are a direct replacement for Standard camshafts so no modifications need to be made. New seals, distributor drive bush and gaskets can also be supplied upon request for an additional cost.
Cam Specification.
Inlet Cam: 252 Duration/9.45mm Lift
Exhaust Cam: 252 Duration/9.45mm Lift
il profilo è molto simile alle famosissime Piper 270 che potete trovare sempre in vendita su PTP o Elise Parts per 500 sterline circa:
Below is a list of the camshafts and applications:
•ARKBP270H - FAST ROAD. Direct Replacement. Designed for 1600/1800 engine. Vernier pulleys advised – uses hydraulic tappets from standard engine.
ARKBP270H
2000- 7000  16 BHP
Inlet Cam: 260 deg .380" 9.65mm
Exhaust Cam: 260 deg .380" 9.65mm
Come potete vedere dai Dati, le TF135, sono leggermente meno spinte delle Piper 270.
Come le Piper270, anche queste le potete installare senza modificare la centralina, rimane l'ultima modifica fattibile contando sul auto adattabilità della nostra centralina, dopo di che si deve per forza passare ad una Emerald.
Certo che per sfruttare al massimo questi alberi a camme, insieme ad altre modifiche, come CF52, collettori d'aspirazione in alluminio del VVC, collettori di scarico 4-2-1, Dekat, e filtro d' aspirazione BMC o ITG, sarebbe più bello poter rimappare una centralina come la Emerald.
2Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Mar 03 Dic 2013, 1:47 pm
Figata pazzesca !
3Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Mer 04 Dic 2013, 12:28 am
Assolutamente si Roby.
Una delle migliori modifiche che si possa fare su una elise S2.
Facili da montare, un intervento economico, con poca spesa e tanta resa.
20cv veri e tutti rabbiosi, con un incremento di coppia e cavalli, in più migliora anche il sound!!
Questa modifica è interna al motore, e quindi non si vede, anche questo conta!!
4Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Mer 04 Dic 2013, 10:26 am
ste
Perché non li monti tu?
5Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Mer 04 Dic 2013, 4:25 pm
E chi ti dice che non lo faccio? Smile
6Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Dom 08 Dic 2013, 12:51 am
Mi sono dimenticato di mettere il prezzo.
Chiedo 410 euro più 8 di spedizione.
Chi è interessato mi può anche mandare una e-mail a kirk1970@libero.it
Andrea.
7Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Dom 29 Dic 2013, 12:05 am
Allora qualche roverista è stanco dei sui 120 cv?  Very Happy
400 euro spedite.
Se volete altre informazioni vi lascio il mio telefono: 3476492831
8Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 03 Gen 2014, 8:19 pm
Alberi a Camme sempre disponibili, in più ho un differenziale Torsen LSD Type B disponibile.
9Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 21 Apr 2017, 1:17 pm
Claudio57
Claudio57
Hai ancora questi alberi a camme ?
10Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 21 Apr 2017, 5:50 pm
Ciao, si. Smile
11Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 21 Apr 2017, 5:54 pm
Claudio57
Claudio57
Puoi dirmi che caratteristiche hanno ?
li hai per caso usati ?
12Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 21 Apr 2017, 5:56 pm
Claudio57
Claudio57
avevo letto un topic di qualcuno che aveva degli alberi di Conrero mi pare e ne parlava molto bene......ma non lo trovo più
13Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 21 Apr 2017, 6:39 pm
Sono come quelli della 135R, sono un delle modifiche migliori da fare ad un rover, possono aumentare i cavalli da 10 a 15, in base alle altre modifiche.
Non li ho ancora montati, ma so che chi li ha messi ha sentito una grande differenza.
Io pensavo di tenermeli e usarli appena posso.
14Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 21 Apr 2017, 6:53 pm
Claudio57
Claudio57
sono nuovi ?
il prezzo è sceso vista la crisi oppure no ? Smile
15Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 21 Apr 2017, 9:13 pm
Scesi? direi proprio di no.
16Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Sab 22 Apr 2017, 9:22 am
Claudio57
Claudio57
Sono nuovi o usati ?
Potresti mandarmi delle foto ? Sai che sto montando l'aspirazione completa in carbonio di elise parts e lo scarico completo .....potrei anche mettere questi .......
Ma devo decidere a breve....
Se preferisci MP o mail va benissimo
17Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Sab 22 Apr 2017, 6:21 pm
Claudio57 ha scritto:Sono nuovi o usati ?
Vedi su questi componenti, è relativo parlare di usati o nuovi, se non mostrano usura o mancanza di materiale, dove sta la differenza?
Considerando quanto costano nuovi, quelli usati in questo specifico caso, valgono quasi uguale.
18Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Mar 05 Ott 2021, 11:21 pm
Silvio
Salve li hai ancora gli alberi in questione ? Io li cerco x modificare la mia mg zr 105, vorrei sapere se sulle camme c'è la sigla che cerco lgc000300 e che prezzo chiedi ? Se chiedi ancora la cifra di 400 euro ti dico già di no poiché cifra assolutamente fuori mercato , aspetto tue notizie grazie
19Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Mar 02 Nov 2021, 7:28 am
Ciao, si ma voglio montarli sulla mia elise.
A Silvio piace questo messaggio.
20Alberi a Camme TF 135 X Rover Empty Re: Alberi a Camme TF 135 X Rover Ven 04 Feb 2022, 12:14 pm
Ciao Andrea, sempre disponibile il Torsen? Nel caso, in che condizioni è è a quanto lo vendi?
